aev front control arm drop brackets
Old 11-01-2010 | 10:38 AM
rhino4bs@yahoo.com's Avatar
Default aev front control arm drop brackets
anyone running these do the work good
Old 11-01-2010 | 09:57 PM
Bypass's Avatar
It depends on the rest of your setup. I had the little Mopar lift and had to add a set of spacers to get to enough height to use them. I originally bought them to cure a right hand pull, which it helped but didn't cure. But ended up keeping them because it made my rig ride way smoother, and have less brake dive. I ended up getting adjustable arms to cure my pull, but he $100 was well worth the other improvements I got.
Old 11-02-2010 | 06:41 AM
jshell73's Avatar
Best $100 mod I've done. It helped dramatically with ride and handling. I couldn't believe how rough every bump was after my lift. While the long term solution is adjustable control arms, you can't beat these for the money.
Old 11-02-2010 | 12:58 PM
JKCliff's Avatar
Came with the AEV 4.5". I love this system! The spring rates are perfect and the ride quality is premium.
Old 11-02-2010 | 09:20 PM
mudhound0530's Avatar
I'd give that a x 2. i love the ride, and the simplicity of design.
