AEV Front Bumper Warning
Just a little heads-up for you guys with AEV bumpers and winches (I have the Warn 9.5si) -- I just found out (the hard way) yesterday that I can't remove my front grill anymore! I was able to pry the top apart enough to slide in a drill, but it made everything a lot harder with the grill in place. Routing wiring from bellow, up and around the swaybar disco, was also a pain. I just finished adding some Hella horns between the rad and grill, and routed some new wiring for the fogs (added a relay to the circuit). I'll have to do a write-up about the horns. I found a really good place for them.
js.
js.
