aev dualsport lift 2.5"...
Lonewolf-you are right that the TF coils will allow you more droop and articulation and yes they do sag over a period of years, almost all coils will. Aev springs are a progressive rate spring so weight doesn't have the same effect on them. Also they are a triple rate spring so the more weight on them the more they push back. I have heavy bumpers and still netted 3+ inches of lift. If you dont have a need to rock crawl and your jeep is a daily driver this is hands down the perfect lift.
AEV Lift
Thanks to all for a good thread read.
I have a 2.5" Old Man Emu on the 4Dr and while stiff as corpse for the first year or so, it has worked in really nicely and is now an awesome ride for a big vehicle. Totally recommend it. But for the 2Dr, since its lighter, I'm leary of it taking a grotesque amount of time to soften up. Being that the 2Dr is also my DD, I'll be going with the AEV 2.5".
Thanks again to all for the input!
Droop is related to shocks travel length and dual rate or triple rate springs (like AEV) allow a better extended lenght than a progressive or constant rate spring.
