Aev correction barket
Old 11-27-2019 | 06:01 AM
liondor1969's Avatar
Default Aev correction barket
Hi i have a jeep rubicon 2014,i buy from company AEV
.please help
how much distance should i measure this after i install this correction braket ?
I forgot to measure before installation,I have a lift kit of 3" and I mounted the bracket to the first hole (recomandation lift kit 2.5" ) I do not know if I installed correctly and if I did not have to mount to the second hole ( recommended hole for lift kit 3.5" )
Please help me with the directions how to check if it is installed correctly on the jeep.
Thanks
Old 11-27-2019 | 06:10 AM
karls10jk's Avatar
You can still measure there and I'd suggest you be in the middle or top hole. I'm on 2.5" lift and in the middle hole for proper caster.
liondor1969 (11-27-2019)
Old 11-27-2019 | 06:17 AM
jadmt's Avatar
JK-Forum Ambassador
Installing the geo brackets will not change That measurement
Old 11-27-2019 | 06:20 AM
jadmt's Avatar
JK-Forum Ambassador
I have 3” actual lift and with mine in the 2.5 hole I have 4.4 and 4.5 caster. If it drives good leave it if it is flighty go to middle hole.
the problem is that I do not know how far it must be..when I mounted the bracket I forgot to measure it before.now it's on the car and it's mounted at the first hole.. (for 2.5")butt i have 3" lift kit..second oprion to mount this is second hole ..this is for 3.5" lift kit recomandation..
ok..than i must check the caster.. must by 4.4 ?
Old 11-27-2019 | 06:23 AM
jadmt's Avatar
JK-Forum Ambassador
The bracket will not change the frame measurement only lifting will change that measurement and the geo brackets don’t lift or lower the jeep
Old 11-27-2019 | 06:38 AM
Ok..but change the cast..what should be the normal cast on Jeep with a lift kit of 3"..to measure to know exactly at which hole to mount the bracket correctly.
tx
Old 11-27-2019 | 06:41 AM
Haw to made this measurement ? or is ok to change to second hole (naw i am on first hole mount)
tx
Old 11-27-2019 | 07:13 AM
jadmt's Avatar
JK-Forum Ambassador
You want caster to be in 4.5 give or take. You need to put it on an alignment rack and get the caster measurement
Old 11-27-2019 | 07:14 AM
jadmt's Avatar
JK-Forum Ambassador
Either top or middle hole will be fine. How does it drive? If steering is a little flighty drop to middle hole if drives fine on the highway leave it
Quick Reply: Aev correction barket
