AEV brackets + aftermarket control arms = _________?
Old 02-08-2016, 05:26 PM
Big_Red_Hog_2013's Avatar
Default AEV brackets + aftermarket control arms = _________?
About to pull the trigger on the new Teraflex Sport Control arms and I am curious if I can leave my AEV brackets on or should I take them off... I love the brackets cuz of how it keeps the arms level and how the brake dive almost disapeared and the handling is so much better... If nobody has any idea I might just leave em on and see how everything measures out... And maybe play the how long will my driveshaft last game...
Any info or advice is much appreciated..
Old 02-08-2016, 05:36 PM
Pape's Avatar
The bracket correct the geometry, if the Tera flex are adjustable and can be the same length as the original or close keeping the bracket is a options.
Old 02-08-2016, 05:47 PM
Well the control arms I'm looking at are fixed length for 2.5-3.5 lifts with factory bushings so they're maintenance free
nthinuf's Avatar
What lift height? Upper or lower arms?
Old 02-08-2016, 05:59 PM
Rock krawler 2.5 and I'd get the whole set of 8
Old 02-08-2016, 06:05 PM
nthinuf's Avatar
The brackets have adjustments for 3 lift heights. So with a 2.5" lift, and arms that correct for that lift height, you would want to use the 3.5 (probably the 4.5"?) holes on the brackets instead of the 2.5".
A side-note:
Both the upper and lower arms say they correct caster for 2.5-3" lift. I assume that means that each set corrects for a 1.25-1.5" lift? (And not that using both sets corrects for a 5-6" lift?)
Old 02-08-2016, 06:41 PM
jadmt's Avatar
I have a 2.5" RK lift and previously ran the aev brackets and then switched to the TF lower front sport arms. I did an alignment check with both to check caster and numbers were very similar ~4.5* I could detect no seat of the pants difference between the two steering wise or braking etc. I prefer the control arms as give better ground clearance.
I just installed both rear TF sport control arms a few days ago and like them. I don't see the need to get the front uppers tho as they are the same length as stock. I am actually running 2.5" RK triple rates up front and 3.5" triple rates in back ala their overland kit. It rides very nice.
Old 02-08-2016, 06:45 PM
jadmt's Avatar
A side-note:
the lower arms are the only ones that correct caster as the upper fixed arms are the same length as factory. The complete set is what is used in the Mopar/teraflex 3" lift. The rear arms are supposed to correct the pinion angle with a 3" lift.
Old 02-08-2016, 06:54 PM
nthinuf's Avatar
Good info to know before throwing parts on. Just reading the blurbs on the website is going to confuse people.
Old 02-09-2016, 04:04 AM
Kojack's Avatar
Just get the lower front TF sport control arms. Keeps your ground clearance and also corrects the caster angle. I am running them too on my leveling system 2" lift.
Quick Reply: AEV brackets + aftermarket control arms = _________?
