AEV 3.5 SC DualSport lift or MOPAR Stage III 3 inch lift
Old 11-05-2013 | 01:54 AM
Bushmaster's Avatar
I'm hearing you on the warranty man. Try for it as something's always better than nothing and the worst they could say is "no" good luck.
Old 11-05-2013 | 02:24 AM
Armergedon007's Avatar
Originally Posted by Armergedon007
This is good news as it saves some $$. If I might ask, where did you read this?
Nevermind. I found it on their website. "On all 2012 JKs equipped with automatic or manual transmissions, you will not need to replace your front driveshaft."
Old 11-05-2013 | 03:23 AM
Landman's Avatar
I have seen pictures on other websites that specifically state that AEV is wrong about not replacing the driveshaft. It will rub the exhaust loop at some point tearing the boot FWIW!
Old 11-05-2013 | 05:12 PM
SiliconTi's Avatar
How bad would it be to drive with the stock drive shaft for a while with the AEV?
That depends on year and transmission. I have an '08 with the manual trans, and should be OK. Some years/transmissions, the shaft may hit the exhaust.
Old 11-05-2013 | 06:33 PM
nittyp's Avatar
Mopar Stage III Lift - Rides better than stock. Nuff Said! Get it! ;-)
Old 11-05-2013 | 10:08 PM
If I wanted to avoid changing drive shafts and saving a bit of coin, would the AEV 2.5 DualSport with the geometry correction brackets be a good choice? I hear it does very well on-road and off.
Old 11-05-2013 | 11:04 PM
Fiveofun's Avatar
I was actually going to create a new thread asking what is the true difference between the AEV 2.5 and 3.5 lifts. The obvious answer is one inch, but is it really? I have read that the 2.5 was designed to provide 2.5 with the AEV bumpers, meaning with the stock bumpers you actually get 3 inches of lift. Has anyone else looked into if the difference really is a true inch? Both lifts state they were designed for 35's.
Old 11-05-2013 | 11:32 PM
RubiX14's Avatar
Originally Posted by nittyp
Attachment 509964
Damn that looks good. I am guessing those are 35's. Diffidently looks like you could fit 37's and flat fenders.
Old 11-06-2013 | 12:03 AM
Their site says the 2.5 kit was designed for those who want the capability and performance of the 3.5 and 4.5 lifts but with a lower stance. I assume the 2.5 kit would provide a performance advantage over a puck lift due to the spring and shock combo.
AEV 2.5 DualSport XT Kit Contents:
• Frequency-tuned, progressive rate springs
• Bilstein 5100 shocks
• Bump-stop spacers
• Rear track bar (LHD only)
• Rear track bar tower
• Brake line drop bracket set
• Front stabilizer end link relocation brackets
AEV 3.5 SC DualSport Kit Contents:
• Bump-stop spacers
• Rear stabilizer end links
• Rear track-bar tower
• Custom bent OE rear track bar
• Brake line drop brackets
• Geometry Correction Front Control Arm Brackets
• AEV High Steer Kit
• Heavy-duty steering damper
• ProCal Module
• Jack Base
Old 11-06-2013 | 02:32 AM
kjeeper10's Avatar
Vet Army
Just installed this lift on a 2 door. He averages just over 2.5" which is going to be safer for the drive shafts. With any lift height you should still keep a eye on them. Especially the front if disconnecting. You should look into a exhaust spacer to protect the slip boot/DS
The biggest differences in the 2 kits
- 1" duh
- higher rear track bar tower
-drag link flip kit
- the brackets with the kit that raise the front sway bar links
- longer rear links (none with 2.5)
Quick Reply: AEV 3.5 SC DualSport lift or MOPAR Stage III 3 inch lift
