AEV 2.5 Lift using Synergy Longer Fixed Lower Control Arms instead of Drop Brackets
I am planning to install the AEV 2.5 Lift on 2014 JKU and I was wondering has anyone used the Synergy Longer Fixed Front Lower Control Arms (#8047) instead of using AEV Drop Brackets to correct the caster. The Synergy Fixed Front Longer Lower Control Arms are .25" longer than stock and are made for 3" lift. I know the caster can be corrected with the Drop Bracket or using Adjustable Lower and Upper Control Arms but I am trying to stay away from any type of adjustments.
Also has any one used MetalCloak Drop Bracket? They look similar to Rancho but have adjustment hole for 2.5, 3.5, and 4.5" lift heights.
You could run that combo. I run the 2.5" Rock Krawler springs with warrior fixed length lower control arms for a 3" lift on my Willys and the ride is great. Obviously, adjustable is the best way to dial things in but the price point of fixed length is better.
Or Tera flex fixed sport lca. perfect on my RK 2.5" lift. slightly shorter then the Synergy lca's and $165 shipped via 4wd.com
prior to these I tried the AEV geo brackets and did not like how low they hang and I can not tell any difference in seat of the pants driving between the two.
I wanted to revive this thread, It's not that old (20 days)
I have an 07 JKU that I bought with a RC 3.25" lift. It could probably use a castor adjustment as I measured it at 1° today and the steering does feel a little touchy. (I'm a new jeep owner...what do I know)
I do not want to have to deal with rebuilding joints or greasing them all the time so these fixed control arms are right up my alley. Plus the lower NVH and quieter ride the rubber bushings offer will make the wife happier.
For front lowers I have found
Teraflex - 22 -13/16
Synergy - 23 - 1/8
JKS - Not sure what length could someone help here
I think that BDS, Icon and the aforementioned Warrior also make fixed control arms but with urethane bushings I think?
Anyone have experience with any of these or others, any input would be appreciated. Also any fixed control arms that I may have missed?
Synergy's are bent to improve ground clearance, not a huge deal for me but I might benefit from it in some trails.
I am mostly daily driving this thing, I plan on 2-3 trips a year to the sand dunes and 2-3 trips a year to the ORV trails in central northern Michigan, also quite sandy. (Plan is the key word in that sentance, plans have a tendency to change) Even when I do go off roading I'm gonna probably baby it, nothing hardcore.
Thanks for any input
Synergy - 23 - 1/8
I wanted to revive this thread, It's not that old (20 days) I have an 07 JKU that I bought with a RC 3.25" lift. It could probably use a castor adjustment as I measured it at 1° today and the steering does feel a little touchy. (I'm a new jeep owner...what do I know) I do not want to have to deal with rebuilding joints or greasing them all the time so these fixed control arms are right up my alley. Plus the lower NVH and quieter ride the rubber bushings offer will make the wife happier. For front lowers I have found Teraflex - 22 -13/16 Synergy - 23 - 1/8 JKS - Not sure what length could someone help here I think that BDS, Icon and the aforementioned Warrior also make fixed control arms but with urethane bushings I think? Anyone have experience with any of these or others, any input would be appreciated. Also any fixed control arms that I may have missed? Synergy's are bent to improve ground clearance, not a huge deal for me but I might benefit from it in some trails. I am mostly daily driving this thing, I plan on 2-3 trips a year to the sand dunes and 2-3 trips a year to the ORV trails in central northern Michigan, also quite sandy. (Plan is the key word in that sentance, plans have a tendency to change) Even when I do go off roading I'm gonna probably baby it, nothing hardcore. Thanks for any input
