Aev 2.5 lift and 35's on rockmonsters. any chance for rubbing.
2012 jk 2 door. buying parts over the winter. wanting to do 2.5 aev lift with rancho dropbrackets and 35x12.50r17 fierce additudes on rockmonsters 8.5 with 4.6 backspacing. front and rear smitybuilt xrc bumpers ( if that makes any diff ) ( stock fenders )
I can find many people running similar setups but not the same and every time i see a bunch of guys saying they have no rubbing issues theres always another guy who apparently is rubbin on everything so for all of you who have a similar set up do you have any clerance issues?
no rubbing
AEV 2.5", 315/70/17 Nitto Trail Grapplers, Quadratec 17 x 8.5" Wheels, 4.7" B.S, Mopar Front Bumper W/ Winch, AEV Tire Carrier, Stock Fenders. Zero clearance issues.
Add the proper bumpstops and clip the rear sway bar link upper bolts. Without proper bumps, you will rub. I'm on a smaller tire and and lift, it'll rub the snot out of a fender under full duress. I chose not to add proper bumps because it then limits uptravel. I'd sooner do a sumospring, but that's me.
It reuses stock rear links, right? I took mine down to one thread past the nut and it stopped the contact. The stock links will contact the stock lines. I'd recommend everyone chop those down to a single thread past the nut- factory, lifted, etc.
