AEV 2.5" Install
Northridge 4X4® Jeep JK Grade 8 Hardware kit - GRADE8
I installed the exact same setup a couple of years ago. I went with the bolt kit from northridge. All about the shouldered bolts. I recommend 2 ratchet straps, you might need some help getting the control arms into the geometry brackets. I did.
For less than $50, why not? Guess I'll add when I order the wheels on Friday!
Rear end done today.....can't work on front til Friday.
will add bolt kit from Northridge and Geo brackets as well.
Easier than I thought, but definitely follow the instructions, in order. Hahahah
For inserting just do reverse and insert via the frame.
Be sure to check all torque 1 week after installation, the fast way to do this is make a trace on each final torqued bolts this way you know when they are loose or if it was torqued in the first place
You'll see the setup is great for DD
