Advice needed regearing jk without overhauling kit.
An extra 500 to use new bearings is not a straight shooter.
The price diff from install kits to overhual kits for both front and rear is only $100
Extra labor if you want to call it that would be maybe $100-$200 MAX.
Also you need to make sure they use new ring gear bolts, New Crush sleeve, Pinion Seal , and they are going to need shims it is almost impossible to regear anything with only factory shims.
David
David
