Advice on modifying my current 4" lift to drive and handle better on-road
Set your toe-in yourself.
Can't set the caster unless you have adjustable control arms.
Can't set the camber as it's fixed.
DIY Alignment - https://www.jk-forum.com/forums/jk-w...ignment-22540/
Or re-align your steering wheel yourself.
Yes agree you can your self. Problem i had was if my toe in and or alignment was indeed off i was only adjusting steering wheel to a bad alignment. Therefore if i have it aligned and truck still pulls one way or the other i can blame the tires and know i have another issue. Was a simple piece of mind for $75.00. SAS sensor in the clockspring is pretty sensitive. The jeeps wont pass our electrical test if wheels are not straight to begin with as the SAS sensor will fail. The jeep can see as little as 4° turn if not lesser.
