Advice
I spoke with a guy from a well established off road garage in the area about putting gussets on. He said sleeves should also be part and that the 30 im running still wont hold up to heavy abuse? (don't know if I would jump or abuse to that level but) so im wondering if I should look for a 44 to replace rather than spend the upgrades in parts and labor
1) gears ( im running 37's)
2) sleeves
3) gussets
4) trusses?
5) axles
6) ect?
anyone offer good news?
2) sleeves
3) gussets
4) trusses?
5) axles
6) ect?
![doh](https://www.jk-forum.com/forums/images/smilies/doh.gif)
Former Vendor
2) sleeves
3) gussets
4) trusses?
5) axles
6) ect?
anyone offer good news?![doh](https://www.jk-forum.com/forums/images/smilies/doh.gif)
2) sleeves
3) gussets
4) trusses?
5) axles
6) ect?
PM us if you would like to discuss in more details.
I spoke with a guy from a well established off road garage in the area about putting gussets on. He said sleeves should also be part and that the 30 im running still wont hold up to heavy abuse? (don't know if I would jump or abuse to that level but) so im wondering if I should look for a 44 to replace rather than spend the upgrades in parts and labor 1) gears ( im running 37's) 2) sleeves 3) gussets 4) trusses? 5) axles 6) ect? anyone offer good news?![doh](https://www.jk-forum.com/forums/images/smilies/doh.gif)
I would build your d30 before buying a stock 44. Just my 2 cents. Same c's, same tubes as your d30
What year is yours? If it's a 2012+ you won't have to worry about needed more than 5.13 for gears so that gets rid of the small ring and pinion theory. Unless you plan to really beat on it, spend $200 to truss and gusset your d30 and drive it.
I would build your d30 before buying a stock 44. Just my 2 cents. Same c's, same tubes as your d30 What year is yours? If it's a 2012+ you won't have to worry about needed more than 5.13 for gears so that gets rid of the small ring and pinion theory. Unless you plan to really beat on it, spend $200 to truss and gusset your d30 and drive it.
