Adjustable rear upper control arms?
Does anybody know of a manufacture that has adjustable upper control arms in the long arm variety? I have the fabtech kit but it only has adjustable lowers and I would really like to push my rear axle back about 1/2"-1" to center my 37's in my rear wheel well. Have minor trimming done but nothing to extensive. Anything is helpful. Thanks.
-Dawn
But by pushing my lowers further back wouldnt that drop my pinion angle since the upper links are remaining stationary? I thought that I would have to adjust both upper and lower links to acheive moving the axle aft and maintaining proper pinion angle. And as far as adjusting pinion angle with stock arms I believe that you need to use cam bolts for such adjustments.
To regain lost wheelbase you need adj rear lowers, along with that you need adj uppers to set your pinion angle correctly. Now, if you were just setting pinion angle and not worried about wheelbase you could use just uppers.but I would not use adj lowers only cause that in effect will drop your pinion angle down. If you have a 4dr and stock driveshaft you might be ok cause the stock ds is a bit more tolerable of angles, but that in itself will cause the joints to wear quicker. You really need both for the rear if you want the wheelbase back.
I'd also like to add that I don't know of any one using cambolts for the rear of a jk. Some cheaper tj kits use this method but are specific to that given kit.And may or may not use a transfer case drop kit with it. This is something not applicable to the jk.
I had a 3" (more like 3.5" until I loaded my JKU down with stuff) installed one year ago. I don't think any changes were made to the pinion angle for the rear DS, and I don't have adjustable control arms back there. Is it possible to adjust pinion angle with the stock control arms? Should I be worried about the pinion angle? I don't think I have had any ill effects. If this qualifies as a thread hijack, I apologize.
-Dawn
-Dawn
if it works without problems i dont think i would be worried.
Former Vendor
You could convert to our independent 3 link in the rear and use our upgrade with the long lowers you have and be good to go if that is something that interests you?
Here is a link to it.
http://www.rockkrawler.com/pages/cat...p?r_itemID=157
Rock Krawler
Rock Krawler
