Adjustable rear sway bar end links
I'm having some trouble finding adj rear swaybar end links for around a 2.5" lift. I'm running RC 2.5 susp with 3/4" spacer, I heard that RC's rear of their kit is actually more like 1.88" to give it a level stance- so i guess my rear is just a bit over 2.5". What brand should I go with and from where? The top 3 online shops are either lacking details for adjustability lengths, or only have adj for 3.5" and up. Any advice would be appreciated!
I use rock krawler adjustable links. If you call rock krawler they will cut the link bars to the length you need. They work great and with the heim joints on them, they require little to no maintenance.
