Adjustable LCA's and still not stable?
Toe will not cause a pull....Period! Caster will cause a pull. A bad tire will cause a pull..Loose or worn out suspension part could cause or lead to a pull..
Your toe should be set a an 1/8 in with the stock tires.
Since this is a right hand drive. I assume that your plus 6 degrees on the left side..Right...If this is the case you probably have a bad tire..Cross rotate the front tires..If it now goes straight or pulls the opposite way you have a bad tire..
Good luck
Good luck
Yes my left is at 6. I did the rotation but it still pulls to the left.
I think you have it close and I noticed your running 35's...Reset your toe at 0 to 1/8 th out. Then you should be set.
