Adjustable front track bar
#51
Ok, thanks for the info. At least I'm understanding how this all works together. Yes , everything seems to be a compromise . But since I'm 80% road and 20% trail , I suppose its the best decision. When I do have an extreme angle on the trail I would expect that I may notice the body representing that extreme angle more so than I did before. Maybe can't take off- camber trails as steep as before?
#52
If you have factory ball joints, it's a good thing to check those occasionally as well as they are the 2nd most common issue on the D30/44 axles once bigger tires are added. You can do a simple test with a shovel and a floor jack. Jack up one side so the tire is a few inches off the ground, put the shovel under the tire and step on the handle using leverage to create upward pressure. Look for movement where the knuckle meets the C. You shouldn't see much vertical movement.
