Adjustable front track bar
#21
For one of the pics you post, do a wide angle shot, from an angle that will show BOTH ends of both the trackbar and draglink in the same pic. (a way to check the steering angles it to open that pic in Paint or whatever and draw straight lines from mounting hole to mounting hole on both bars - then compare just how parallel those lines are.)
And for posting pics, I've never looked into any of the hosting deals and just upload straight from my computer. Click the Picture/Postcard looking icon in the strip at the top there, click 'Browse Your Device', navigate to the pic I want, click Open, then click Upload. Depending on the size it shows up as, I may go back to the pic and resize it then re-upload. But it's a fairly straight-forward process to post
#22
3.5" Coils + 1" Spacers, if I read it right.
If the trackbar is flexing as much as you indicate, swapping to a stouter bar will help, and I will echo the opinion that you will likely see an additional improvement by going back to the stock pitman and raising the axle end of the draglink instead. Keep the bracket installed, as noted. (just to verify: the trackbar is raised from the axle, not dropped from the frame, correct?) And as another thought, which type of rear bracket is installed, frame or axle? (the number of people seeking help for handling/driveability issues with that specific kit ... heh) Both front and rear track bar brackets are rough country that came with the lift kit and both attach to the axle. orrect on the 3.5 lift and 1" coil spacer. It was fairly level by tape measure, but horrible by the eye. I'm one of those that does not like the rake look. I know some do. I talked to RC about this, they said to install a 1" spacer if I didn't like the rake. I had everything aligned after I installed the lift and coil spacerC
#23
Correction, 3.5" "Rough Country" prone to sag coils and a 1" spacer.
I understand it's a safe assumption he likely needs a DL flip and likely currently has a drop pitman arm and thus the reason its working at all without currently having a DL flip installed but it's better to be safe than sorry. Already we can see the assumption was made that he likely had a frame side TB drop bracket but now we're learning he actually has axle side track bar brackets. A picture is worth a 1000 words was my thought to remove any assumptions and doubts.
#24
Both front and rear track bar brackets are rough country that came with the lift kit and both attach to the axle. Correct on the 3.5 lift and 1" coil spacer. It was fairly level by tape measure, but horrible by the eye. I'm one of those that does not like the rake look. I know some do. I talked to RC about this, they said to install a 1" spacer if I didn't like the rake. I had everything aligned after I installed the lift and coil spacer
Kelley1 (11-07-2019)
#25
Rednroll (11-06-2019)
#26
Ok guys, a little off the subject but I need help. The track bar info is very good. Thanks
But I have a tie rod stabilizer that I think may be instilled incorrectly. On. the axle there is the bracket for the track bar . The rod. end of stabilizer is attached to same bolt. Seems to me sit should be attached more in straight line with tie rod. See photos. Any help would be appreciated. If you could respond to mmflytie@att.net I would greatly appreciate it.
Marc
You see how its attached with same bolt as track bar? That seems to put it at a weird angle.
There is a hole below track bar bolt that I could use. Would that be better?
Marc
#27
yup, that is where it should go. you may need a spacer/sleeve to smoosh between the SS and the bracket mount for clearance, but that is the hole it should go in. That TB bolt shouldn't be used for anything other than holding the TB.
#29
I'ld also suggest getting a pic of your steering box where the drag link connects to the pitman arm so we can better see what you have going on there since RC lifts often use a drop pitman arm which can be troublesome.
I'm kind of surprised seeing a 3.5in RC lift without one of silly dual steering stabilizers installed which can often cause problems.
#30
Doh! Wrong hole for that Steering Stabilizer to be inserted into. Sorry, I couldn't resist.
