Adjustable Front Track Bar
I am having issues with my front track bar relocation bracket having play in it. I've tightened it to spec several times, but it still comes loose again over a period of a couple of weeks. Plus, my axle is about an inch off center.
SO... I ordered a new adj front track bar from Northridge and I'm just waiting for it to come in.
I just want to make sure that I have this correct, whenever I put on the adj front track bar on up front, I need to remove the Rough Country bracket that came with the lift and just put new track bar directly in the factory mount, correct?
Sorry to be such a newb, but I installed the lift myself, and I wanna make sure I'm doing the right thing.
JK-Forum Founder
Ahhhh... I wasn't aware of that. Yeah, the RC lift came with a dropped pitman arm.
So when I install the adj track bar, I need to remove the bracket and the dropped pitman arm. Makes sense, hopefully I would've realized that whenever I went to do the install.
Good thing I didn't throw my old pitman arm away!
This is the way to go right? Why would RC spend the money making a bracket for the factory track bar, and a pitman arm... instead of just putting an adjustable track bar in the kit?
Is there any drawbacks to me going to an adjustable track bar?
Sorry for all the questions!
JK-Forum Founder
Might want to consider beefing up the the bracket where your trackbar connects to the axle. Its a weak point on the JK's!
Hmmm... so you're saying my best bet, is to keep the bracket AND adjust the track bar down enough that I can use both.. and keep the dropped pitman arm?
Whenever I have my JK on level ground.. looking from the front, my axle looks to be sticking out more on the passenger side by about 1 1/2.. maybe 2 inches.
JK-Forum Founder
a track bar relocation bracket and dropped pitman arm are something that you should have if you have a 4" lift or higher. what they do is correct your steering geometery so that it is closer to stock again and this will help give you better handling. a lot of kits actually include both a relocation bracket and an adjustable track bar as often times, the bracket will not provide enough correction to recenter your axle. needless to say, you optimally want both and, you may want to consider getting the bracket you have welded to the frame.
Thanks WOL!
