Adjustable Front Lower Control Arm Question
Im running RC front lower control arms that are at 23" in length. My rig pulls to the right a little so just wondering if that can be corrected by making one of the control arms longer than the other. Which arm should I make longer and how much? Will it mess up my pinion angle on my front driveshaft? Thanks
JK-Forum Founder
you are most likely experiencing radial pull and that is normal on a lot of big off road tires. i WOULD NOT recommend that you set your control arm longer. you have a solid front axle and even if you could add cross caster to your axle, it would be minimal at best and doing so would put a LOT of strain on your bushings and axle housing. doing this will lead to premature bushing failure or worse.
yes my jeep was pulling right after installing AEV 3.5 lift... 35 inch toyos... aligned twice could not get pull out, could not get caster even close to factory specs as AEV advertises with their drop brackets... maybe the axle was bent or worped hell i dont know, tried everything to trouble shoot. Finally, added adjustable control arms (lower), as i felt there were no other options, and the right one is adjusted about an inch longer than the left one.. im guessing this may not be good ... but the pull is out and the jeep drives straight.. how harmful really is this?????. i do not wheel, pretty much all pavement with some offroad camping and exploring but not often.
