Adjustable Control Arms Jam Nuts
Old 08-18-2016 | 12:20 PM
RiverCityOffroad's Avatar
Former Vendor
Just get you a big ole crescent wrench or open end from Harbor Freight and go to town. I say HF in this instance because they will rarely be used for someone that isn't constantly doing installs.
Old 08-18-2016 | 12:48 PM
14Sport's Avatar
^That's what I use. Never had one come loose yet. The two footer. I've had joints come out though. You buy a Wrangler and all of a sudden you need monster sizes of every tool you already have. It's like having a tractor I would imagine.
Name:	2' Crescent 001.JPG
Old 08-18-2016 | 01:28 PM
kjeeper10's Avatar
Vet Army
Was that from Goody? The pic looks familiar and I've got a few of these that I've been asked to double-check.
No kjeeper haha I got the idea from him.
I don't like using a regular crescent wrench because of the slop. They don't seem to grab the not tight rounding off the edges or slipping.
Old 08-18-2016 | 01:37 PM
karls10jk's Avatar
I was asking about the jig, but I'm on the same page- having that crescent slip is tough. They don't fit well on the track bar nuts either.
Old 08-18-2016 | 01:42 PM
kjeeper10's Avatar
Vet Army
I made the jig. Goody used a jig similar to stock mounting points. This means he had to use spacers to prevent the joint from twisting.
Old 08-18-2016 | 01:45 PM
kjeeper10's Avatar
Vet Army
The only arms I tightened on the jeep,
rear uppers. I used pieces of metal to keep the joints centered
Old 08-18-2016 | 01:56 PM
14Sport's Avatar
Never had that problem even with the cheap HF wrench. Never came loose, never slipped.
Now I'm wondering if I tighten them enough. I don't kill myself on it. Whatever a 180 pound guy at 2 feet comes out to. Maybe 200 lbs. with the extra foot of leverage.
Old 08-18-2016 | 05:44 PM
PsychoCupcake's Avatar
Also you can torque stripe them after tightening. Then you can just glance at them for a quick and easy way to check to make sure nothing is loose.
Old 08-18-2016 | 05:51 PM
Extremneon's Avatar
This is what I do on almost every bolt and nut. Makes checking things easy.
Old 08-19-2016 | 07:50 AM
matt852's Avatar
Is that when you make a mark over the nut and a neighbor surface and see later if they budge?
