adjustable control arms
Is there anybody running these with a budget boost for when they upgrade, stronger control arms or for aftermarket driveshafts.
I personally think it would be a good way to do things if you cannot afford to do it all in one swoop. Get everything ready for the size springs you want to run and then after you have everything else done, swap in the shocks and springs.
Sponsoring Vendor
Alpha Expedition
Alpha Expedition
It makes sense. at 3" driveshaft mods arerecommended right? you are only 0.5" from that. That sure is close in size. I sure don't see what it would hurt. I think caster is needed at 2" and up personally. But that is just my opinion.
I have the RC 2.5" lift with 2.2 shocks. Steering was okay, but obviously more "flighty", so I installed the TF front LCAs to allow adjusting the caster. I don't believe on a LWB that the driveshafts are an issue at 2.5" of lift.
