Adj Rear Link Question
I am not sure how much i need to adjust the currie adj rears to make up for a 3 inch lift? Do i jsut make it 2.5 inch longer then stock? and i planned on moving my rears to the front is that cool? Thanks
Rears to the front ??
You should be able to get a starting measurement from Currie, I centered my axle and the adjusted the arm until it lined up with the mounting bracket hole.
well i want to install rear adj sway links on my 3 inch lift and i am not sure what the right measurment would be and was wonderig how you determine if its correct. And will the stock rear ones be ok for the front with the electronic diso or shoul di get adj for those as well?
