Adj control arm setting?
Hello quick question I'm trying to install my adj control arm in the front I have rear upper already and just got front lower. What the idea range for a 4inch suspension. Keep in mind I have a control arm drop bracket
awesome I was wondering if I should lose the drop bracket, I just didn't know if it would ride better with the drop bracket and then both upper and lower arms at 4inch
You don't need both. But no harm in running brackets and adj arms. Gives you more fine tuning for the caster/pinion.
The brackets will drop the angles of the arms, making them more parallel to the frame. In theory, this improves handling/cornering/nose diving/whatever.
With a 4" lift I found I had to add so much castor to prevent vibs that my front coils bowed enough to contact the sway bar links. Of course this was with a cv shaft, with the factory shaft you'll be fine with much less castor but you won't be able to flex on a curb without hitting the exhaust. What's your setup?
I have been thinking of removing it and inning just running upper and kier arms
The front & rear lower control arms cents the axles in the wheel houses and align the bump stops. The uppers set caster/pinion angle in front and pinion angle in the rear. If you do the front lowers only the setting is a bit longer than if you do both lowers and uppers, but not by much. Best rule of thumb, set them to 23 1/8" to start, have the caster checked and adjust a bit to get the best compromise between caster & pinion angle that delivers good steering an no front driveline vibration. With a 4" lift and short arms I ran them at 23 1/4" with 5 degrees caster. I have manual hubs, so the DL vibe issue was moot.
