Adding a spacer puck????
Old 04-05-2014 | 11:30 AM
campman's Avatar
Default Adding a spacer puck????
Have a Rough Country 2.5 coil lift already. Wanting a little bit higher in the rear. Was thinking about adding a Daystar 3/4 spacer to the rear. Has anyone done this????
Old 04-05-2014 | 06:08 PM
onlyone's Avatar
It would be just fine other than having a big rake to it. What are you going to do to the front? I also have a new set if you want them.
Old 04-06-2014 | 09:23 AM
easttnruby's Avatar
Are you packing heavy load in the rear? Hell, I run a I inch spacer up front with my lift to level it out. Seems like lifting the rear would give you a real forward lean.
Old 04-06-2014 | 07:45 PM
campman's Avatar
It is very level with the lift. Hard top is on....maybe that has something to do with it. Putting the 35in spare may drop it more. Just tired of the headlight flash @ night.
Old 04-06-2014 | 08:26 PM
Ncb's Avatar
Ncb
Adjust the headlights. Cheaper and easier than adding spring spacers.
Old 04-06-2014 | 10:07 PM
BlackRockBurner's Avatar
2X on headlight adjustment. Throw what little light the jeep puts out on the road instead of the sky.
