adding a locker
OK I got an 08 X with the 3.73 Dana 44 rear end. but what is the gear ratio of the front Dana 30? I see the lockers for the Dana 30 with 3.73 or higher ratio, and the ones for the Dana 44 are for 3.73 or lower ratio. I'm not planning on doing any serious wheeling this year, but down the road might. Do I really need lockers front and rear for moderate wheeling? If not should I go with front or rear.
Or am I just over thinking this whole thing, I never had lockers on my YJ, but it did have limited slip rear diff.
Former Vendor
Dual lockers on an offcamber slippery surface for example the rear of the vehicle will tend to want to slip down the surface getting you into a bad spot in quite a hurry.
In any case there is no rush, advance your vehicle as your own driver skill advances. I started off with one locker , found my limits with it then moved on to the 2nd locker and found my limits with that. Sometimes not always the wisest choice to find your limit but knowing your own ability and not just the vehicles is a must.
i would just go with a front locker for now. I dont have any lockers, just the factory LSD and i would say my wheeling falls into the moderate category. As long as you pick good lines and know when to brake or gas you can get by with the LSD. I agree with the above, dont get mod crazy, mod as you need it. Wheel it like it is and decide what you need to suite your style and then start building. Hard to ever accomplish anything if you dont have a goal
i think the front and rear are the same from the factory so whatever your window sticker says. If you cant find it or didnt have it you can email Jeep with your VIN # and ask them and they can give you a full list of vehicle specs
