actual tire height
Old 12-21-2008 | 04:26 PM
miket@teterop.com's Avatar
Default actual tire height
have 315/17 hanook rf10s and love them,however,they only meaure 34?? Ready to proram hypertech and suprised at 34 inch height. Is this normal????
Old 12-21-2008 | 04:53 PM
Suffolk JK's Avatar
http://www.1010tires.com/tiresizecalculator.asp
Use that.
Old 12-21-2008 | 04:58 PM
TexsDream77's Avatar
Completly normal. The wider the wheel the lesser the actual diameter will be and the wider the section width. The opposite is true of a narrower wheel. This is why the tire manufacturers specs include what rim it was measured on. Also most 35's are between 34 and 34.5"
Old 12-21-2008 | 05:07 PM
Default Thanks, ill sleep better!
Guess i should have gone 37s!
Old 12-21-2008 | 05:18 PM
RedneckJeep's Avatar
Keep in mind too that the actual tire height also depends on how much "squish" the Jeep has on the tire. It may well measure 35" in static "off the Jeep" trim, but when the weight of the Jeep is added, that can change significiantly....especially with a load range C.
Old 12-21-2008 | 05:33 PM
AZJeeper's Avatar
Originally Posted by N2rock
yes, that is probably correct. I have 35" KM2's, and programmed the Hypertec at 33.25" to get proper speedometer reading.
X2!
I'll set it to 33" if I know I'm going to be aired down most of the trip. Still off a little.
The spare measures 35" diameter with no weight on it, so keep in mind the wheel well is still filled side-to-side by a 35" tire.
Old 12-22-2008 | 08:09 AM
retep's Avatar
Default acc. tire size
I just did a Accu-pro install and was supprized, my 35" cooper sst's measured
33.5". I did the mark the tire and ground thing and calculation. So far the
garman and the speedo are reading the same speed. The tires and 4:88
gears have approx. 20k miles. 07 unlimited rubi,3"tera flex lift.
Life is Good! Peter
Old 12-22-2008 | 08:44 AM
jkkat's Avatar
My Procomp Xterrains measure 34.8 or 34.75 on a 35 tire @ 33 psi
Old 12-22-2008 | 03:51 PM
keno4x4's Avatar
thanks suffolk jk for the tire size link. I was just looking but this info is great
Old 12-22-2008 | 03:59 PM
Fermin's Avatar
Kinda like wood shop. Its really a 2"x4".
Quick Reply: actual tire height
