Actual diameter of your 37" tires?
Old 02-06-2010, 12:20 PM
Former Member
RA070424's Avatar
Originally Posted by jcole
You got ripped buddy, I'd ask for my 1.2" worth of money back on those tires.
Which equals $11.76 per tire...
Old 02-06-2010, 12:57 PM
spinlock's Avatar
Originally Posted by davidwm71
Shouldn't the skinnier rim make the tire stand taller? Also I've always been told don't go more than 4 inch wider than your rim. Any shops I have talked to wont even mount the tire for you.
or is whats happening is you are squeezing so much you lose some side wall height?
You are correct, the narrow rim will make the total height of the tire taller.
The 4" rule used to be/is an old guide line some shops still apply, but most of them use the recommended rim width published by the tire manufacturers, which has a safety factor built in.
With the proliferation of tall and wide tires many shops will go slightly beyond that range. Running 12.5" wide tires on the stock 7.5" rims is a common practice in this forum.
Old 02-06-2010, 01:09 PM
jcole's Avatar
On that 8 inch rim you are squeezing the hell out of that tire. That make the tire stand taller when on tht rim. Put the same tires on the correct rim and you will measure a shorter overall height.
The correct wheel is an 8" wide wheel if you actually wheel and air down the tires. 10" wide wheel will lose beads easily vs an 8".
Old 02-06-2010, 08:11 PM
davidwm71's Avatar
As explained to me in the post prior to yours... I was going by older guide lines.
Old 02-07-2010, 04:31 PM
Toyotafreak1965's Avatar
My 37x13.5 Nitto mud grapplers measure 35.5 mounted on my AEV beadlocks.
Old 02-07-2010, 04:44 PM
dlincoln91's Avatar
just to put this out there i feel like a 7.5 wheel would be better than an 8 on the trails just for the fact that this weekend wheeling aired down to 12 psi come down a creek side one of my tires almost broke the bead but luckily just burped out a bunch of air
Quick Reply: Actual diameter of your 37" tires?
