ACE rails coming and gotta grind body mount washer
Old 05-09-2012, 08:00 AM
jrhsvt's Avatar
Default ACE rails coming and gotta grind body mount washer
...and I don't have a grinder/sander. I assume I can't take them out and drive my jeep somewhere to get this done. Frustrating because from looking at the video, it's like, literally 30secs total of grinding for all of them to get them to fit. Is it time to man up and just buy a bench grinder for this one little job? Any suggestions? Like maybe some cheaper tool I could use to get these things to fit...?
Old 05-09-2012, 08:10 AM
afpilot82's Avatar
Just buy a grinder, then you will find all sorts of things to cut on your Jeep! If you don't see yourself needing it much, get a cheap one from Harbor Freight.
Old 05-09-2012, 08:18 AM
Hook-Em's Avatar
X2 on buying a grinder. You can get one at Lowe's for as little as $30. Don't take my word for it, check it out yourself.
h ttp://www.lowes.com/pd_296496-353-9295-01_0__?productId=3255470&Ntt=grinder&pl=1&currentU RL=%2Fpl__0__s%3FNtt%3Dgrinder&facetInfo=
Old 05-09-2012, 08:44 AM
TriJeepV's Avatar
Better yet, tell your boss that the company you work for needs one. Worked out perfect.
Old 05-09-2012, 09:31 AM
jrhsvt's Avatar
Thanks; didn't realize how cheap they can be. You're probably right, I'll be looking for other things to cut/grind on this thing. Maybe even a new hobby will be born.
Old 05-09-2012, 10:28 AM
rays0852's Avatar
I thought I had tools until I bought a Jeep.
I now have almost 2 of everything including vise grips, socket sets, clamps, hammers, etc.
I added a bench grinder, creepy crawler, 3 ton floor jack, extra jack stands, rivet gun, tons of torx bits, breaker bar, impact adapters, etc, etc, etc, etc.
Old 05-09-2012, 10:40 AM
kosmos's Avatar
Or just saw a bit off like I did
Old 05-09-2012, 10:55 AM
Mr. Drummond's Avatar
I was going to buy a grinder, but i thought what the heck I will try it with my belt sander - turned it upside down, took about 45 minutes for all 6. Just medium 80 grit. Just FYI.
Old 05-09-2012, 11:39 AM
HELLBENDER-JK's Avatar
Just do us all a favor and don't drive it anywhere w/o the bolts in place.
Old 05-09-2012, 11:43 AM
Blade's Avatar
If you really don't warrant the bench grinder you could always use a metal file. It will take a little longer, but it will get the job done. I vote bench grinder
Quick Reply: ACE rails coming and gotta grind body mount washer
