ABS and Traction Control Issues
Hey everyone. For the past few days I've had the ABS and Traction Control warning lights coming on and haven't been able to track down a reason why. I'll do my best to explain what is going on.
Three days ago, while going around a long right hand turn, I felt the rear brakes step in as if the traction control was trying to reduce any slip/spin. This was in the rain and figured it was normal. However, a minute later the ABS and traction control lights came on simultaneously, then went off about a minute later. When the next right hand curve I came up, the exact same thing happened, but the warning lights stayed on until the Jeep was turned off.
After two days of this, it seems that any right hand turn, above 30mph seems to result in the same thing (traction control stepping in when in shouldn't followed by the two warning lights), no matter how aggressive or mild I enter into the turn. None of this occurs while going around left handed turns, which is what is confusing me. Steering wheel has been centered and the Jeep was aligned no more than 3 months ago.
Jeep Specs are as follows: 2012 JKUR, 6 speed, 2.5" AEV lift, 37" Toyo RT's, stock axles, gears (4.10's), driveshafts, and control arms.
Any type of info would be helpful. Hoping that someone has had a similar issue and knows of a solution! Otherwise its going to the stealership on Monday.
Also might be worth to note: Brought my Jeep in for an new BJ's, sleeve, and gussets 3 months ago. They preformed the alignment afterwards and straightened up the steering wheel.
Could be a wheel sensor but I would expect the lights to be on all the time or randomly, not just in right hand turns. You could try swapping them around if nothing is loose or broken. But I'll stay with my first assessment. Let us know how you make out for future searchers.
