ABS lights on after regear
Pulled the ABS codes last night:
C101F - Right front wheel speed comparative performance
C2116 - Antilock brake system pump motor supply low voltage
C1015 - Right front wheel speed sensor circuit
How's it possible that the pump failed? I did relocate the vacuum pump a while ago, gonna go ahead and check the wiring after work to make sure everything is still nice and tight. I just wanted a re-gear and lockers...
When calibrating tire size be sure to use the actual measured height of your tire and not the advertised height. This caused my ABS and ESP to act up a little until changed. Apparently my bald metric 35's were closer to 32".
