ABS lights on after regear
Old 10-03-2016, 07:30 AM
BoraBora's Avatar
Pulled the ABS codes last night:
C101F - Right front wheel speed comparative performance
C2116 - Antilock brake system pump motor supply low voltage
C1015 - Right front wheel speed sensor circuit
How's it possible that the pump failed? I did relocate the vacuum pump a while ago, gonna go ahead and check the wiring after work to make sure everything is still nice and tight. I just wanted a re-gear and lockers...
Old 10-03-2016, 07:55 AM
Ajkaz's Avatar
When calibrating tire size be sure to use the actual measured height of your tire and not the advertised height. This caused my ABS and ESP to act up a little until changed. Apparently my bald metric 35's were closer to 32".
Quick Reply: ABS lights on after regear
