ABS lights on after regear
Just picked up my JK from having Yukon 4.56 gears installed. Problem is now the ABS lights are on.
The guys at the shop seemed a little confused since the lines are fine, and said the lights should reset after "50 or so starts." Is there any validity behind this?
They did say the sensors were a little dirty. It's a 2015 with 22k miles on it. I do wheel it, but is there a chance the sensors already went bad? Or maybe they got damaged during the gear install by accident?
If the ABS light is on, you can use an OBDII code reader which supports ABS codes and the code will usually point you in the direction of the problem. At least that is what I ended up doing. I went to an autoparts store which offered free code reading. However, the key is to find one that has a code reader which will read ABS codes, since most of the scanners will only read ECM codes.
Yeah I wasn't buying the "it'll reset after 50 starts."
Took a look under the rear, and the plug on the passenger side is clearly broken and they tried to zip tie it back together. Does anyone know where I can find just the plug? I'm going to take it back after 500 miles anyways and let them check the pattern.....and also fix my ABS they tried to bandaid.
Update on this:
Replaced the broken plug...lights were still on. Went ahead and replaced both rear sensors....still nothing. Ended up with new sensors all around. Lights on the dash are still there.
Every time I start the Jeep up and accelerate from a stop, the rear will lock up as if the ESP is kicking in on one side. Happens for 20ish feet, and then everything feels fine after.
Anyone have any idea what might be going on? I'm stumped.
Yep, did that after the regear with my Pro-Cal. Although I did disconnect the battery twice after putting the new sensors in...do I need to flash it again?
So I had the same issue with my 2007. Ended up leaving the gear ratio set to the stock setting, and only adjusting the tire size to fix the speedo. All the lights when off and the traction control quit freaking out!
Hmm, I'll give that a shot. My JK is a 6 speed....so ultimately it shouldn't matter if it's flashed to 4.56 right?
Edit: just tried...lights are still there and it still locks up. I feel like I'm chasing my tail here...really don't wanna take it to the dealer.
