9/16" bolts but where???
So I had an instance with death wobble after lifting my Jeep and have read about swapping the factory bolts with 9/16" grade 8 bolts. I replaced the front lca bolts on the axle side and the new adjustable track bar bolts but what else?
I found that the passenger side lca bolt was loose along with the sway bar link. After swapping and tightening I hit every hole I could find and I'm good but it can't hurt to swap any others.
Thanks in advance for any info.
That's what I was looking for. I figured the rear of the front lca but wasn't sure about the rear tb. Thanks for the info. No oval holes and everything seems to be much tighter!!!
Hit the bridge gap that caused the wobble this morning and all was good!
BTW if you get out on the trails anytime soon let me know...
