9/16 bolt replacement
Replaced all 8 LCA bolts with the 9/16 Synnergy kit from EAD. Also did the 2 bolts on the rear Trackbar. As far as the front trackbar, I only replaced the passenger side bolt as I am assuming the driver side bolt is a 14 mm. I guess I should go ahead and see if the 9/16 bolt will fit, but from what I have read on the forum its likely that the bolt is 14mm. My question is this. Should I replace the front drivers side TB bolt or just leave this one alone as I have changed out everything else? None of my local auto parts shops have a grade 8 ( or higher) 14 mm bolt. If i should replace it I guess I will have to order the bolt online
Originally Posted by Blakspire
The 9/16" will fit. I just did this to my Jeep.
Its a 2010 JKUR. You should not have to recenter the steering wheel with just the 9/16" bolt upgrade. I did because I installed a whole hell of a lot more than just that
Anyway, all of my 9/16 bolts fit. I've got a FT front TB, and all went well.
I had the dealer install my F911 kit on my '10 with a 2" Mopar lift a few weeks ago. They installed all but 2, but didn't tell my which or why. Well it finally stopped raining here in Portland, so I crawled under the Jeep yesterday to check and the two they did not install are not the ones I expected: the bolts that attach the lower control arms to the front axle. Is there something special about those? I notice that they seem to have those cam washers. Can I just replace them with my F911's?
