6inch rough country long arm kit
Old 09-02-2016, 07:18 AM
  #21
Kojack's Avatar
Originally Posted by kjeeper10
Funny how somebody can install a 2.5 lift and complain of flighty steering until caster correction is added. Then theres the few with 6" lifts w/ 1-2° caster and claim it steers great. I know ride in general is subjective but keeping the jeep straight at 70 mph is not.
I have no problem with a tall lift, if it were me id plan for a aftermarket housing with added caster and pinion.
The kit is not too bad. As said i would stay around 3-4" tops. Radius arms get mixed opinions. Ive never rid in a JK with them but my brother had the RC arms on a cherokee. The arms were beefy, It handled fine and he beat that thing. Bushings all looked good when removed later when the jeep was parted out. RC shocks get mixed reviews as well and im not a fan of DPA's. At least RC now uses a raised TB bracket. Replace the DPA with a flipped DL instead. I will admit RC looks to have been improved and a lot of their stuff doesn't look too bad. That and CS from what i see is top notch if you ever have a problem.
I know hey? I installed a teraflex leveling kit and had to correct my caster. I can't imagine how shitty these rigs are that the owners say they have 1 or 2 deg of caster and say they drive great. A call bullshit on them all day long.
Old 09-02-2016, 07:49 AM
  #22
Jasoncinpean's Avatar
Originally Posted by Biginboca
I don't know the pros and cons of radius arms, but my gut says they aren't great for a daily driver. Radius arms are so simplistic why would oems not be using them if they had advantages? Instead of using them jeep put a lot of thought into the 4 link design so I'm guessing it must be better since it's also definitely more complicated. I also suspect castor changes more as suspension cycles with radius arms probably resulting in bizarre handling at high speeds. (This is all conjecture on my part.) Secondly what's the point of a 6" lift and all the issues it presents (driveline, low castor, and bump steer) if you don't get more clearance than a 3" short arm lift? Here's a pic of my short arm lift with 3" springs above that long arm kit. Are you really gaining anything with those extra inches height and all that crap hanging under your belly? Edit: I went outside and just took a picture of my rig from about the same angle as that one of the radius arm set up for a better comparison...
Thanks for your reply! You make a good argument! I'm currently running 37s on my lift and atleast need some adjustable control arms thanks for taking the time and taking those photos! I just want to fit these 37s better so I'm not cutting my trees every time the rear flexs
Old 09-02-2016, 07:51 AM
  #23
Funny how somebody can install a 2.5 lift and complain of flighty steering until caster correction is added. Then theres the few with 6" lifts w/ 1-2° caster and claim it steers great. I know ride in general is subjective but keeping the jeep straight at 70 mph is not. I have no problem with a tall lift, if it were me id plan for a aftermarket housing with added caster and pinion. The kit is not too bad. As said i would stay around 3-4" tops. Radius arms get mixed opinions. Ive never rid in a JK with them but my brother had the RC arms on a cherokee. The arms were beefy, It handled fine and he beat that thing. Bushings all looked good when removed later when the jeep was parted out. RC shocks get mixed reviews as well and im not a fan of DPA's. At least RC now uses a raised TB bracket. Replace the DPA with a flipped DL instead. I will admit RC looks to have been improved and a lot of their stuff doesn't look too bad. That and CS from what i see is top notch if you ever have a problem.
Looking at biginbicos post it doesn't appear like the guy could fit 40s on his lift it doesn't appear like the RC control arms would adjust far enough to allow 40s to fit comfortable. It looks like even with 37s they are getting close to the pinch seam.
Old 09-02-2016, 07:55 AM
  #24
kjeeper10's Avatar
I assume theres more adjustment to those arms. 40's are tough regardless, besides the width trimming needs to be done to clear on up travel.
Old 09-02-2016, 08:19 AM
  #25
kjeeper10's Avatar
Must be the dual stabs ... Boom
Old 09-02-2016, 08:43 AM
  #26
In your opinion or anyone else's what size lift should I go with and be able to clear 40s? Thanks! Would you totally rule this lift out? Apperently they have a 5 year warrenty in springs and a 3 year on there shocks that I won't be using anyway. Lifetime on everything else they say. Also to replace all the bushings in the control arms costs me about 100 in parts.
Old 09-02-2016, 08:58 AM
  #27
nthinuf's Avatar
How much, if any, have you trimmed?
Not the best solution, but have you considered adding any bumpstop to keep the tires from moving up so far?
You mentioned arms, would moving the axle back a bit help enough to stop the contact?
Old 09-02-2016, 09:24 AM
  #28
Originally Posted by nthinuf
How much, if any, have you trimmed? Not the best solution, but have you considered adding any bumpstop to keep the tires from moving up so far? You mentioned arms, would moving the axle back a bit help enough to stop the contact?
Arms would do a world of a difference I could run 37s comfortably. I believe. The lift I got back in the day was a very cheap budget with fixed arms. This is a 3.5inch lift all suspension though.
Old 09-02-2016, 09:45 AM
  #29
kjeeper10's Avatar
3.5-4" is enough for lift to run 40's but with some work.
Old 09-02-2016, 10:11 AM
  #30
sa29560's Avatar
Looks to me like a good set of control arms, drive shafts, and some money on a good sawzall or die grinder instead of buying that big o long arm lift.
You have some space in those wheel wells and plenty of lift as it is. I have a 3.5" lift on 35s and could easily fit 38s with some cutting the way my CAs are setup. You definitely need some CAs in the rear to get that axle back a bit for some clearance.
Just my opinion, buy the 40s, and some good parts, you can make it work as she stands.
Quick Reply: 6inch rough country long arm kit
