6-Spd Shifter bezel
I broke my shifter bezel when installing my new Tuffy console and I need a new one. Has anyone got any suggestions? I'm looking at either the Drake or the NCM, both listed in two prominent catalogues. Not looking for BLING, just something that's beefier than plastic piece and works well with the steel console. I still have the original rubber shift boot. Was wondering if these replacement bezels require the original boot--the upper one that you see, NOT the lower one that's attached to the tranny. Thanks!!
Vedo
Vedo
I too would like a more beefy replacement for the plastic ring and not bling. Thought about buying the drake aluminum one and painting it to match the console. Also, making a new fastening system than the facory plastic bottom piece. I'm not home to play with it but I am hoping to just drill and tap the console for the side bolts of the trim piece.
I ordered touch up paint in an aerosol can. I scuffed the alum and then put about 6 coats of paint and 3 coats of clear coat. It turned out well. Im sure you could bed line it with rattle can and I think that could look pretty sharp. Good luck.
