5 directional tire rotation
True. The treps are, was just thinking most m/ts aren't. My bad.
As for left rear, floor it a few times and see which tires spins. In an open diff rwd vehicle the right rear almost always takes most of the load. Add an lsd and its about even.
But can we please keep this thread on topic and not derail it to the workings of an open diff please.
If one tire spins upon acceleration, it's simply because it has less traction than the other.
As long as the tires have equal traction, the work done by each tire is equal.
I stuck with front to back when I had claws, just left the spare hanging.
Ideally you would dismount and remount the tires to ensure that they saw the correct amount of inner and outer wear but that gets quite expensive.
Right. What's your thoughts on post #2 and #3? That way I'm only flipping one tire.
Wouldn't how you rotate directional tires depend on the tread design?
Some tires can be used in one direction because of how they direct water from the contact patch.
Other designs are directional for best traction, but I have read that after a few thousand miles, they are not so directional any more.
Per your request not going off on tangent about open diffs.
If you're running bead locks you could swap the backwards tire around on the rim each time you rotate since can do at home assuming you just use balancing breads. Would still get the front to rear "flattening" of tread. Would probably be a pita though every few thousand miles.
