5" Backspacing on 37's info and help
Is anyone running a 5" Backspace on 37's?? If so what should I expect to rub besides wheel at full lock?? i'm running 18x9 35's and they hit slightly at full lock. Also, If I go 37's should they be 12.5 or 13.5 ?? I'm not changing rims and wanted to see if I mostly do pavement with slight offroad if it would be a big deal or not?? I currently have a RK 2.5" Max Travel with stock fenders but looking to go Flat tube fenders... Thanks for your info and help..
Put them on, turn the wheel, and see where you are rubbing (or likely to rub with any up/down/side movement while driving). Add a washer to the steer stop. Check again. Add another washer. Check again. You will be limiting your turning radius with each washer, so wheel spacers or new wheels would be your better option - and depending on what you find, may be the only option.
For the most part it's a pavement pounder so If I gotta do a 6 point turn instead of 3 point I'm ok with it.. Not so much worried about bumping at full lock more worried if I buy the 37's can I put them on and ride down the street without any other problems. I love my rims so I'm not really looking to change them an not really wanting to do spacers... So I'm guessing washers to be able to correct steering bumps.. ??
And yes, narrower tread/sidewalls would need less backspace/steer stop adjustment than wider - for a given height.
Thank you very much for all your help guys!! Brings light to what needs to be done... Either go 4.5" BS or washers and check all carefully!! Thanks again
