5:13's and 35's
3.73 gears and 35's????
who on here is running 3.73 gears with 35" tires? i have a 6 spd.
How would it run?
How would it run?
Here is the best gear calculator on the net. It lets you do a side by side comparison.
http://grimmjeeper.com/gears
BTW: The 6sp in the JK is the NSG-370, close ratio (you need to select it to get the proper transmission gearing).
But, at 65mph, with 35's, you will be running 2558 rpm in 6th gear.
