5.13 gears from Northridge, 2 different packages
So i am finally ordering my 5.13 gears for my Rubicon... But on Northridge's site, he has the JK overhaul package for $550, and then something that just says Rubicon package for $565.... Am I missing something, the $550 set have a drop down Rubicon option.... Any ideas?
http://www.northridge4x4.com/proddet...-GEAR-OVERHAUL
http://www.northridge4x4.com/proddet...G-RUBICON-GEAR
Stick with this one:
Chose Rubicon and 5.13 set.
Why are you going with the overhaul and not the install kit by the way?
I am also doing Superior Axle Tube seals at the same time.. Figured it couldnt hurt and there not that expensive.... Cant wait for my 5.13's
I reused mine. They will be fine if your Jeep is low mileage.
No one can argue that's it's a bad idea to replace the bearings, but in real life, pinion and carrier bearings should last 100,000+ with 2 or 3 oil changes.
