5.13 or 5.38 for 37" automatic
Old 06-01-2012 | 08:30 AM
wayoflife's Avatar
JK-Forum Founder
Originally Posted by chris@offroadevolution
What year is your JK? the new 2012 does not need as much of a gear or any at all.
agreed. running 37" nitto trail grapplers on our 12 with an auto and 4.10 gears and feel no need to regear.
Old 06-01-2012 | 10:30 AM
bigbluejk's Avatar
Wow that is pretty impressive power in the 12's
Old 06-01-2012 | 11:05 AM
V00D0013's Avatar
It's an 07 rubi. I do a fare share of off roading but what makes it worse is now I am going to be tugging a 2000+ trailer/ base camp.
Old 06-01-2012 | 11:06 AM
V00D0013's Avatar
By the way thanks guys, keep 'em coming. How much did u guys spend for gears and install kits?
Old 06-01-2012 | 11:08 AM
bigbluejk's Avatar
superior gears with bearings and install stuff plus labor was $1250ish for me.
Old 06-01-2012 | 11:17 AM
bsharp704's Avatar
for most people, 5.38 is definitely a good ratio to go with but, the pinion is really really small in a dana 44 and, if you wheel hard and often, a 5.13's will be a lot stronger and a better option to go with. granted, i was running 40's at the time but, when i ran 5.38's in my factory 44, i soon found myself wishing i had stuck with 5.13's.
Correct but you also had a manual, i believe the OP has an automatic. That alone will make a big performance difference.
Old 06-01-2012 | 11:21 AM
BadPunkin's Avatar
5.38s in my 6 speed with 37 Toyos and I am happy. I only went to the 5.38s for towing otherwise 5.13s all the way. If they break, they break. You have to pay to play
Old 06-01-2012 | 12:38 PM
wayoflife's Avatar
JK-Forum Founder
meaning?
as i have said, 5.38 is a good ratio and one that most people will never have a problem with. but, it doesn't change the fact that the pinion is really really small and will be a weak point.
Old 06-01-2012 | 03:09 PM
hagausaf's Avatar
5.38's easily. Should'nt even be a discussion. Go big or go home.
Old 06-06-2012 | 11:35 AM
V00D0013's Avatar
Right on! N
Quick Reply: 5.13 or 5.38 for 37" automatic
