40s rubbing front fender well
How many of you running 40s had to trim the front wheel well? I'm installing axles and 40s now and it looks like the tires are going to rub the the wheel wells (where the pinch seam starts). I still have to flex it out to see if so and how bad. Had to quit for the night though. I have the axle pushed forward about an inch right now (again just in the beginning stages of setting everything up).
Since you have 40s I'm assuming you have 8 arms and are fully centered, or are in the process of doing so. There will possibly be some rub, just keep that geometry in mind. Again, I'm only just moving to 35s so don't take my word. Hopefully someone will chime in.
It is going to depend on your set up. I can't recall cutting up front but I have the front pushed forward 3" and run long arms. You may catch that rear part of the fender with a short arm.
