4' superlift with 37s
Old 10-11-2010, 12:47 AM
tmann's Avatar
Default 4' superlift with 37s
Hello all, im new to the jk world. I have a 2dr 07 sahara that i wanna do a 4' superlift with some 37' km2's. I would like to hear from anyone running the same set up. From what i understand there is some modification involved with getting the 37's to fit properly Thanx.
Old 10-11-2010, 01:14 AM
ericsurfffs's Avatar
remember the km2s run about an inch smaller then advertised and your most defiantly going to need to trim the pinch seam
Old 10-11-2010, 06:47 AM
Little Fella's Avatar
From a guy who owns the Superlift 4". Don't waste your money. The ride is unbearably rough on the road. Look at teraflex. And your 37's will fit fine with a 4" lift. As said above, a little trimming will be required inside the rear wheelwell on the leading edge.
Old 10-11-2010, 06:56 AM
mkjeep's Avatar
I changed my Superlift to a 4in Teraflex, if that tells you anything. The rear sagged really bad with weight on it. I added a 1 3/4 in spacer to it so I wasn't riding nose up when loaded. The front trackbar that comes with the kit is not the greatest either.
Old 10-11-2010, 06:59 AM
jksierra's Avatar
Yep. We have a 4" Teraflex with 37" KM2's on our JK and had to trim the pinch seams. We still have stock fenders (sigh) and also trimmed out a piece of the rear inner fender wells. Now there is no rubbing.
Old 10-11-2010, 07:46 PM
tmann's Avatar
Yeah the tera flex is a little high $$ but ill check into it. Thanx for the replys
Old 10-11-2010, 07:56 PM
mkjeep's Avatar
Consider the $$ you save by getting a better kit the first time.
1st lift- RE BB
2nd lift-4in Superlift
Now-Teraflex 4in- I'm happy now( for awhile anyway, haha)Prolly go longarm in a year or two when the jk is paid off.
Old 10-12-2010, 05:24 PM
Jvic's Avatar
x2 on dont waste money on superlift. Got it on my 2 dr rubi and it rides like log wagon. Im slowly upgrading to teraflex suspension one piece at a time.
Old 10-12-2010, 05:28 PM
mikeyut3's Avatar
not to highjack the thread, but KM2s run 1" smaller than advertised? I was gonna run 35s...so they are basically 34s by all other manufacturers' standards? Thanks.
Old 10-12-2010, 05:59 PM
codysanders's Avatar
my km2 35's ran 33 inches aired up. i have a 9.5 wide wheel though. km2's run small.
i am running 37 pitbull rockers on a 2.5" ome lt lift. it is not all about hight it is about the bump stops and lcg.
Quick Reply: 4' superlift with 37s
