4" lift kit; I want the truth
JK-Forum Founder
i would recommend picking up a JE Reel or TeraFlex shaft and both are available from our sponsoring vendors. if you get a 1310, you will be looking at about $450 and if you were to get a real heavy duty 1350, you can add about $100 or so more.
JK-Forum Founder
sorry jake, i was working on it when work got in the way
if your dealer installed it, i would think they should cover it but then again, they should have also known it would be a problem to do this in the first place.
as far as your safety goes, you will be just fine. the boot is only there to keep grease in the spline shaft and now that it's exposed, it will probably dry out and squeak - but that's about it.
I have a 2dr Auto with a 3 inch lift and my front drive shaft boot has come loose from the clamp. It now rests at the rear of the front drive shaft in a twisted mess! I am wondering if the dealer will cover it under warranty, since they installed the lift? Am I gonna throw a shaft? I wish I could afford new drive shafts but I think I am gonna have to go see the dealer.
My front and rear drive shafts are the OEM shafts! Great there goes mo money down the tubes.... so much for my EVO lever
I have spoken to a few guys that have had their driveshafts repalced under warranty due to early failure from a lift. You just have to find a dealer that is lift friendly. A couple of the dealers where I live sell lifted, brand new JK's on their lot. One of them happens to be where I bought my JK, and they are good about covering parts under warranty on lifted JK's.
Sponsoring Vendor
Off Road Evolution Rep
Eddie,
I know you're a busy guy no worries and thanks I was just giving you a hard time! I will go talk to my buddy at Orange Coast and see what he can do for me.
JaKe
JaKe
Good info guys, keep it coming, answer my question now.
So I got a 2 dr rubi, and i wanna go with the same setup. But I don't plan on changing the driveshaft for at least a month or two after i install the lift. Will the last at least a month or 2?
Thanks guys.
Thanks guys.
my 4dr auto with a 4" superlift lasted about 3000 miles and 2 trips before I noticed the dreaded torn boot. I replaced mine with a Tom Woods (it's what my local shop recommended, they did the install)
As long as you don't wheel, you should be fine. It's only when articulating that the front driveshaft will make contact and tear the boot. And in the rear, the 2 door will be at a steeper angle then a 4 door, but should last quite a while. Once you notice that your shaft is spitting grease out all over the place (meaning your cv boot has torn), it's time to replace it.
