4" Lift
Old 02-02-2017 | 10:24 AM
  #21
kjeeper10's Avatar
Vet Army
Its not a horrible kit. I dont like the shocks and here TF is changing over to the new Falcons soon.
Old 02-02-2017 | 10:30 AM
  #22
DJ1's Avatar
DJ1
Former Member
For that price tag though, you'd think TF would at least throw in some dual-rate coils...
Old 02-02-2017 | 10:33 AM
  #23
Electech99's Avatar
Originally Posted by DJ1
If you paid $2700 for the Teraflex kit, you could have gotten much better components going with something like a MetalCloak or JKS lift. Better springs, better shocks, better control arms in my opinion..... Even the AEV which comes with the high steer kit would have saved you quite a bit of money if you wanted to keep the stock control arms .
Damn, now I'm wanting to send this kit back before it ever even gets here
Old 02-02-2017 | 10:49 AM
  #24
DJ1's Avatar
DJ1
Former Member
Problem is they'll probably stiff you with a re-stocking charge....
...but yeah, based on the $2700 spent on the TF, I would have looked at the following:
1. MetalCloak RockSport @ $2800 but it's a complete kit less the programmer
2. MetalCloak Fox @ $3250 - again complete kit less the programmer
3. JKS J-spec 3.5" @ $2465 - priced with programmer included but you only get the lower control arms which is fine....
4. AEV 3.5" DualSport RS ($2250) or the SC version ($1800) - priced with programmer included and you're using geometry correction brackets instead of adjustable or aftermarket fixed length beefier control arms BUT you can always add better control arms later which is what I did with my AEV kit after selling the correction brackets for ~ $100....
...also NorthRidge has that Teraflex kit you linked for like $2340 so hopefully you didn't pay the $2700 in either case.....
Unless you are planning to do a lot of rock crawling, I think you could have easily gotten away with a good 2.5" lift and a 1.5" body lift. Even then, that's no slouch either since that's basically what I'm currently running. If you run 35's, then no problem.
** Also these are mfg prices. You can get them cheaper with forum discount codes for at least the JKS. MetalCloak and AEV typically don't discount....
Old 02-02-2017 | 11:00 AM
  #25
hieneken49's Avatar
I just did a quick build and thats with a steering correction bracket. same shocks as you would have got. and quick disconnect sway bar links for the front.
ID:	665834Click image for larger version
edit: i accidently added front arms instead of rears, but it would be about the same price
Old 02-02-2017 | 11:04 AM
  #26
Electech99's Avatar
Problem is they'll probably stiff you with a re-stocking charge.... ...but yeah, based on the $2700 spent on the TF, I would have looked at the following: 1. MetalCloak RockSport @ $2800 but it's a complete kit less the programmer 2. MetalCloak Fox @ $3250 - again complete kit less the programmer 3. JKS J-spec 3.5" @ $2465 - priced with programmer included but you only get the lower control arms which is fine.... 4. AEV 3.5" DualSport RS ($2250) or the SC version ($1800) - priced with programmer included and you're using geometry correction brackets instead of adjustable or aftermarket fixed length beefier control arms BUT you can always add better control arms later which is what I did with my AEV kit after selling the correction brackets for ~ $100.... ...also NorthRidge has that Teraflex kit you linked for like $2340 so hopefully you didn't pay the $2700 in either case..... .
No I didn't pay $2700, but I guess I jumped the gun again. So before I order a high steer kit, is this what I should get or what? If so are there any other parts I'll need for this? I'm ordered both front and back driveshafts already. I'm looking at the programmers right now too.
http://www.quadratec.com/products/16191_9006_07.htm
http://www.quadratec.com/products/16191_9007_07.htm
Old 02-02-2017 | 11:20 AM
  #27
DJ1's Avatar
DJ1
Former Member
You're going to need the kit so if you must stick with Teraflex, here are 2 options....
Name:	Screen Shot 2017-02-02 at 11.16.34 AM.png
Name:	Screen Shot 2017-02-02 at 11.14.56 AM.png
Personally I'm not a fan of frame drop brackets but since you're already knee deep in it and for simplicity's sake....
https://www.northridge4x4.com/fits/2...-link-flip-kit
use discount code "JKFORUM" and save some $...
Old 02-02-2017 | 11:35 AM
  #28
DJ1's Avatar
DJ1
Former Member
Attachment 665834Attachment 665835
That's actually a pretty good build for standard coils + struts. I would have opted for Fox shocks which I'm guessing would have probably put it around $2300-$2400.
Old 02-02-2017 | 11:40 AM
  #29
DJ1's Avatar
DJ1
Former Member
Attachment 665836
Attachment 665837
...BTW, the FRAME BRACE bracket on the TF kit requires welding so if you want to keep things strictly bolt-on, you're most likely going to have to piece-meal a kit together starting with a front axle trackbar bracket....
*** Call one of the vendors on the forum like NorthRidge and let them step through it with you. It'll be much easier lol....
Old 02-02-2017 | 11:51 AM
  #30
Electech99's Avatar
Ok so I was able to get quadratec to stop shipment on almost everything and give me a store credit. If you had to pick a 4" Lift from there, which one would it be? I found this AEV kit but not sure if this is the best one to go with.
http://www.quadratec.com/products/16502_4100_07.htm
Quick Reply: 4" Lift
