4 inch suspension lift plus coil spring spacers??
#21
Like I said, you don't want to hear it. If someone says something you don't like you get all shitty and insulting. You are basically a dick and why would someone want to help out someone like that.
I am just fucking with you. You will be fine at 6.5" of lift and not sure why you are not going with 8" or 10". The bigger the better right?
#22
I have never told anyone to run what I have, I actually tell people not to do what I have done. You like making shit up. I almost always recommend people that use their jeeps as a daily driver run a 2-2.5" with 35" max tires. If you like to go off road quite a bit 37's are a good place to be but with the necessary mods. My set up is a long arm double triangulated 4 link rear with 4 link + pan hard up front running 18" travel 3" tripple bypass and 2.5" coil overs on each corner with 2.5" front hydraulic bump stops and 2" hydraulic bump stops in the rear. I limit my front travel to 16" due to drive shaft bind, 7" up 9" down travel. Rear has 21" of actual travel 9" up 12" down before I get bind. I run a 72" WMS dana 60 front and a 68" WMS dana 80 rear with 2" wheel adapters. My wheel base is stretched to 112" and sits on 40"x12.5" Baja compound KR3 tires on Method bead locks with 4.5" of back spacing. My actual lift height is around 3.5". My entire set up is custom and there are only a handful of rigs that are even close to the set up I have. It's more buggy than jeep at this point.
If so many people are running 6.5" of lift with absolutely no issues why did you even ask the question? If you have any knowledge of suspensions you would see what the issues are going to be. I would say people that are installing 6.5" of lift have no idea of what they are doing and would be interested in seeing the entire build before making the statement that they have no issues as all.
I thought you were running OME coils and shocks?
And thank you for allowing me to help YOU. I feel so honored.
#24
#25
I gave you an answer for the rear and said you would have issues up front. You asked what issues so don't give me that shit about only asking about the rear. You still did not answer the simple question I asked about your set up.
I assume you have a factory front axle with a CV front shaft with greasable joints. While this type of driveshaft is ok for a mild lift, it is actually the wrong route to go with the factory non caster corrected axle. Because the fact you have to rotate the pinion down to get acceptable caster in the front axle a single u-joint at each end is the proper driveshaft to use. A sealed u-joint should also be used due to the strength differences. As you put more angle in a U-joint you loose strength and introduce vibrations. The more lift you have the more angle the u-joints have. U-joints also do not have unlimited misalignments, at a point your u-joint will bind on itself and break it or the yoke. I find you will typically break the yoke and recommend using a flange mount and make sure limit travel at the differential as not to put the drive line in bind. Since I am just some douchebag on the internet here is a good bit of driveline geometry info with photos to help you understand.
https://4xshaft.com/blogs/general-te...onversion-kits
I have never seen you talk about high steer. I assume you are still running the factory set up. Bump steer and axle shift will be a big deal if so. Flat steering links are ideal for eliminating these things and are best achieved with 3.5-4" of lift and high steer. Going higher reintroduces the affects of bump steer and axle shift.
IMO the rear drop brackets are a waste of money and the same thing can be achieved with better results by addressing the axle brackets. You will get not only the geometry is better but you also get better clearance under the axle where many people get hung up on off road.
A rear raised track bar on the axle is highly recommended for a better ride, don't know if you have that or not but the flatter that rear track bar the better.
I don't know the specs on your shocks so I can't tell if you will have issues or not. I would doubt you have the shocks and bumps correctly set up since most people won't take the time to do it right.
You will experience more body roll and will be "tippy" off road.
What size tires are you running anyway?
#26
I would not put a lot of trust into Adams, I had one of their builds come to my shop and it was all messed up. Was scary to drive. Was told it was a $100,000 build. RK junk for the suspension with improperly sized king smoothies. Only good thing about the build is that they used Fusion dana 60 axles.
#27
Front Setup: drop brackets and all four adj arms, drag link flip, adj trackbar with raise bracket, HD tie rod, 12.5 links, outboard shock mounts, 24.5 inch brake lines, adj bump stops set to 3 inches currently, and an adams 1310 extreme duty non greasable driveshaft. Current castor 4.7 so roughly 1.3 degrees of pinion angle. Almost exactly what the manufacturer recommends. -.01 degrees steer ahead.
Rear setup: drop brackets, all four adj arms, adj trackbar with raise bracket, 12.75 links, adj bumpstops, 24.5 inch brake lines, sway bar relo brackets. Thrust angle -.08 degrees.
The only thing I don’t have in the rear is an aftermarket driveshaft, which is what I wanted to know about, and you start talking about issues in the front. I assumed you saw the part where I said I already have an aftermarket front driveshaft so I’m figuring you meant some other kind of issues. So I asked you what issues would I have then and you started being a douche. I’m more than happy to listen to people and do my own research from there, but it sounds like you didn’t actually read what I said and assumed I’m doing all this on a factory front shaft and who knows what else when that’s just not the case.
#28
Details matter, you still never answered the questions of what tire size and what front axle. I know metal cloak well. I have even wheeled with most of the guys there. Its good you got the solid u-joints in the front driveshaft. I never said anything about you running a factory front driveshaft, you are running an incorrect front shaft since it is a double Cardone and don't have a caster corrected axle. You are a dumb ass and I am done with you. Enjoy the fucked up ride you are building.
#29
#30
I'm surprised you guys made it this long.....
