4 Bolt Size Questions?
In the process of installing my two new axles and transfer case I miss placed three bolts and was wondering if anyone knew their sizes or where I could pick up replacement ones.
1. the small bolt that holds the rear abs sensor on to the axle.
2. The bolt that holds the factory rear brake line bracket to the frame
3. The Nut that secures the drag link to the axle.
4. The size of the copper crush washers on the banjo bold for the brake lines
Thank you for you help.
JK-Forum Founder
i could probably tell you what size socket/wrench you'd need for all these if you think that would help.
1. the small bolt that holds the rear abs sensor on to the axle = pretty sure 8mm
2. The bolt that holds the factory rear brake line bracket to the frame = 10mm
3. The Nut that secures the drag link to the axle = 21mm
4. The size of the copper crush washers on the banjo bold for the brake lines = the bolt needs a 15mm
