4.88's or 5.13's
I'm currently on 33s with 5.13s. Went with the 5.13 because I plan on moving up to 37s once I get everything built right. I'm hitting about 2600rpm at 70mph on the GPS which is about perfect IMO on the highway
I think you picked the right setup. I have an auto w/35's and 5.13's Spins about 2300 at ~70 mph. Lots of big hills here so it makes a huge difference there. Average about 14-15 mpg (mostly city) so ok but hell it is just a big brick rolling. You'll be happy with them!
Thanks! Good to get info from another jeeper with the same set up.
I think the 5.13 with 315s/35s is the right gear. This is what I have on my 2011 Rubicon automatic. My mpg is around 14.0-14.3 currently with a root top tent and gobi rack installed. Very happy.
Originally, I had the stock tires and the 5.13s and was not happy, after adding the lift and bigger tires, the gearing feels right.
I am still shocked at how many jeepers don't mind running 3:73 gears. You will over work your engine and trans. And do damage over time. Like the quote "I just can't do it captain...I don't have the power".
It has a lot to do with your situation. I rarely tow anything, the terrain here is flat, and I usually don't get above 50mph. My '11 JKU on 37" tires gets 15mpg on 4.10s. Would anyone else regear?
