4.88 vs 5.38 with 34's (285/75R17) Auto JKU
Old 01-19-2012, 03:47 PM
  #21
hagausaf's Avatar
first off, 34's is not a common size and i would steer you away from them just for that. if you're looking at 285's, that would be the better way to go. having said that, 5.38 is WAY OVER THE TOP for the size tire you are looking at. 4.88 will be plenty fine and, so long as you make sure to calibrate your speedo, you will not have the shifting issues you've apparently read about.
Please explain why 5.38's are way over the top. I have 5.38's, 35" KM2's (really measure 33.75") and the JK drives like a champ here in Colorado. Get 14 mpgs around town and about 17 on the highway. I have an auto tranny just like the OP.
Old 01-20-2012, 09:52 AM
  #22
gunbo75's Avatar
i have the same 08 jku with steel bumpers and winch and tire size so 488 are still ok.
Old 01-20-2012, 10:33 AM
  #23
nd501's Avatar
My problem is I have a 2011 and the programmer I won't isn't available yet, so I am stuck with 3.73's and my transmission hunting going down the interstate.
Old 01-20-2012, 11:30 AM
  #24
Jeeptang's Avatar
The 285 is essentially a 34" tire if you do the math. 33.8, but close enough to 34........................
Old 01-20-2012, 11:54 AM
  #25
nd501's Avatar
I guess I am confused, my speedometer is already re-calibrated for my 35in tires, but how will that help me change my shift points and not run at 1500rpms on the interstate doing 70 constantly downshifting. I guess I don't know all the functions I can do with it.
Old 01-20-2012, 12:12 PM
  #26
DGriz's Avatar
Originally Posted by zmotorsports
Why are you stuck because it is a 2011. You don't need a "tuner" to recalibrate the PCM, a recalibration module will take care of the calibration issues but not add any HP/torque. I am running 5.38 gears in my 2011 and purchased the AEV Procal to recalibrate my PCM to compensate for gear ratio and tire sizes. Runs like a champ and everything shifts great.
At 70 MPH it is running right at 2500 RPM down the interstate. This is with 35" KM2s measuring 33.75" in height.
Personally I am glad I didn't go with the 5.13 gears which I was originally considering. I am very pleased with the decision to go with the 5.38.
Mike.
Can you explain what it is about the 5.38 that pleases you? And is this a DD or primarily off-road vehicle? How would you expect the 5.13 to perform differently for you? How is the 5.38 different from the stock gears/stock tire performance?
Quick Reply: 4.88 vs 5.38 with 34's (285/75R17) Auto JKU
