4.88 gears versus 5.13 for 4 door auto jk
Old 06-23-2011, 08:48 AM
  #21
roadking54's Avatar
Originally Posted by cameron7
I have a question though
With 5.13s how is your top speed though? because I have to drive on the highway everyday
What do you mean? How fast can I go?
My top speed is no different with 5.13's then it was with 3.73's, other then I can actually hold the higher rpm, maintain speed on inclines, and pass other vehicles at 80 mph. Before I would have been climbing a slight hwy incline in the far right lane, pedal to the floor, going 55 mph with the truckers.
Old 06-23-2011, 08:57 AM
  #22
weebus's Avatar
Default gears
if you have a dana 30 up front the pnion head on a 5:13 set gets very small under heavy load you might get gear failure as long as you dont live in mountainous terrain 4:88 will get by just my .02
Old 06-23-2011, 09:08 AM
  #23
roadking54's Avatar
Originally Posted by TheDirtman
I don't see how you can get 3 different rpms at 70 mph. The tow mode turns off the od so you can have 2 different gears at 2 different rpm's but there is no way a tuner can change the gears in your transmission. running 3rd gear at 70 mph will have the same rpm no matter what tune you have. The tuner will just adjust the rpm point at which the gears shift.
not sure, I just look at what rpm I'm holding at 70 mph with different tunes, and that's the result. Maybe it's a tachometer gremlin....or my speedo is slighly off at different measurements.
Old 06-23-2011, 09:51 AM
  #24
nthinuf's Avatar
Originally Posted by dwhitt74
But isn't that using the 3rd gear ratio of 1:1? with overdrive, the rpm's will be less right? I'm just diving into the re-gearing swamp of opinions and posts and trying to get the facts. Thanks!
The chart gives numbers for OD On for autos and 6th gear for manuals. If you want the OD Off rpms, (the 1:1 ratio) divide the OD On rpm by .69
Old 06-23-2011, 09:52 AM
  #25
aermotor's Avatar
Originally Posted by archijeff
4:88 with 35's are closer to stock ratio. But all depends on what your re-gearing for. Do you pull anything?
I would hope we all want better performance than simply stock...
Old 06-23-2011, 10:07 AM
  #26
Sponsoring Vendor
Northridge4x4's Avatar
So I have not read the entire thread but 35" tires and the auto 5.13's are the way to go.
Go 488's and I personally dont think you will be happy .
David
Old 06-23-2011, 10:14 AM
  #27
nthinuf's Avatar
Bingo. Auto's are under-geared straight from the factory. If you all haven't done so already, follow the link posted back on page one of this thread and look at the numbers. An auto with 5.13's and 35's produces 75 rear wheel horsepower at 70mph!!! And that is with 5.13's. 4.88's would have your rpm lower, which means your hp at 70 will be correspondingly lower, and your ability to hold OD will be lower, which means you will drop out of OD more frequently, which means your gas mileage drops, which means...
I realize that I may be a bit biased, living at altitude and driving inclines all day long, but even down at sea level I will take my 5.38's over 4.88's any day of the week. (I have a light foot, and don't spend much time in rocks, so the strength difference between 4.88/5.13/5.38 is not an issue for me. I figure that if I am doing something stupid enough to break 5.38's, it's a good bet that 4.88's would have snapped as well).
Old 06-23-2011, 10:50 AM
  #28
ejfernet's Avatar
I have a 2011 4-door auto with 4.88's. I have a light foot and it drives great around town. However, in hills, with cargo or the added weight aftermarket bumpers there is a significant degradation of performance. If I had to do it over I would go with 5.13's.
Old 06-23-2011, 11:36 AM
  #29
bymoosek's Avatar
Everybody seems to compare 4.88's to 5.13's. Not much said about 5.38's. I see the chart will put me in the blue w/ 33"s and in the green if I go 35's in the future running 5.38's. So for me I have ruled out the 4.88's thanks to all of your input, but still undecided on the 5.38's. Is there a good reason to stay away from them?
Old 06-23-2011, 02:23 PM
  #30
jeepmedic's Avatar
I remember David and I having this exact converstation about 2 years ago...5.13s and never looked back
David
Quick Reply: 4.88 gears versus 5.13 for 4 door auto jk
